So, i have two resistors, one is burnt, the other one is ok and is just to compare.
What colors do you see, and what values? Then i will tell you what measured value has the good one.
The burnt one i see RED-BLACK-SILVER-GOLD-GREEN this is incorrect as most calculators cannot input silver as third ring.
The good one i see VIOLET-GREEN-SILVER-GOLD-RED this is also incorrect as above.
Majority on fb said third ring is grey not silver, but the measured good resistor contradicts them.
What is your opinion?
The resistor is in the source of a mosfet in a pc atx psu, the mosfet also shorted.
Thank you.
