Author Topic: Resistor help  (Read 375 times)
Offline CramboneTopic starter
Resistor help
« on: February 23, 2024, 08:47:34 pm »
I have a board that has a resistor marked 4R70 it measures 2.22mm long. Is this 4.7 ohms? What case code is that size?
Drew
Offline Wil_Bloodworth
Re: Resistor help
« Reply #1 on: February 23, 2024, 08:56:19 pm »
Can you post a photo of the resistor?
- Wil
Online selcuk
  • Country: tr
Re: Resistor help
« Reply #2 on: February 23, 2024, 09:02:16 pm »
It can be 0805 4.7 ohm. You may refer to the first table in this link:
https://eepower.com/resistor-guide/resistor-standards-and-codes/resistor-sizes-and-packages/
The following users thanked this post: Crambone
Re: Resistor help
« Reply #3 on: February 23, 2024, 09:05:57 pm »
Yes sorry I thought I posted it but forgot.
It’s on a LAMBDA Power supply
Re: Resistor help
« Reply #4 on: February 23, 2024, 09:31:55 pm »
Yes. 4.7 Ohms.
- Wil
Offline tooki
Re: Resistor help
« Reply #5 on: February 24, 2024, 07:00:04 pm »
Measure the width of the chip cap, so that you have at least one dimension whose length is not affected by the thickness of the solder joints.
Offline BillyO
Re: Resistor help
« Reply #6 on: February 24, 2024, 08:28:47 pm »
They are 0805.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
