Hi everyone,
(I'm new here, so pardon me, if its the wrong section)
I am trying to "reverse engineer" a shunt PCB from my battery manager (Victron Energy BMV-602S) The manager is able to monitor two batteries - "advanced" monitoring of a leisure battery (B1) and "basic" monitoring of a starter battery (B2.)
The board of my shunt is lost, so I reconstructed the original circuit (I once ordered one and just traced the PCB paths and sent it back again) and want to etch my own PCB. The board consists of:
- RJ25 connector (to the management unit)
- two terminals for positive poles of the batteries (+B1 and +B2)
- two contact pads (to each end of the shunt)
- two capacitors (C1 and C2)
- one resistor (R1)
The resistor (marked R1 on the PCB) does not look like a "usual" resistor. For me it seems to be a sort of non-linear thermistor or varistor and may have something todo with this "advanced" monitoring functionality for the leisure battery (B1).
A photo of an original shunt with a board is below in the images section, the bespoken resistor is in the red box. The resistor has a label "R010 B7V" on it.
I could identify both caps by their marking (104J250), but the resistor looks very odd to me.
I already searched around which resistor types exist and which it could be. From a form-factor it may be a thyristor or thermistor to me.
A week ago or so I tried my luck on the electronics stack exchange but with no luck.
Can you help me to answer this questions:
What type of resistor is it?
What function does it have?
What resistor can I use as a replacement in my PCB?Images:Original shunt with a board (red box is the bespoken resistor R1):
Close-up picture of the resistor R1:
The circuit of the PCB I reconstructed (Box meanings: red: resistor R1, green: battery positive terminals, blue: RJ25 connector):
General connection guide (documentation) of the shunt and the monitoring unit for two batteries:
Thank you for your help!
Max
