hi all, i'm new to LWMESH and i would like to use LWMESH1.2.1 version.. i would like to make one coordinator and 5 router and 2 end devices.. the end devices send its Address and some sensor data to Coordinator. End device place so far from coordinator and it should route to Coordinator.. When it route the data a decision check should take at the side of router.. Where i can add that decision check at router side? i have to analyse the data come to router(sensor data value greater than some value).. then the router should take decision like the data should route or ignore... How can it be possible? Please help to solve this..
