Author Topic: Keeping reset pin low for a while during startup?  (Read 1857 times)
Offline fubar.grTopic starter
  • Country: gr
    • Fubar.gr
« on: October 07, 2016, 04:59:06 am »
I implemented the 555 monostable circuit shown here, using a Intersil ICM7555 SMD CMOS chip:
It works as intended, save for a small inconvenience. When the circuit is first powered up, the output is turned on for the predetermined time interval, as if the pushbutton was pressed.
I believe the problem is that the voltage on Threshold pin takes some time to rise due to the pullup resistor (R2). I fed 12 Volts directly to the Threshlod pin, bypassing the pullup and the problem went away.
One possible solution I came up with, is to keep the Reset pin low for a while during startup, by connecting a resistor and capacitor in this fashion:
Will this work?
Offline danadak
Re: Keeping reset pin low for a while during startup?
« Reply #1 on: October 07, 2016, 09:29:05 am »
A page of applications, and one that shows another approach.
http://home.cogeco.ca/~rpaisley4/LM555.html#10
"Power-Up Reset For 555 Timers" section on page.
Regards, Dana.
The following users thanked this post: fubar.gr
Offline rob77
  • Country: sk
« Reply #2 on: October 07, 2016, 10:27:13 am »
you need to add a way of discharging the reset capacitor, otherwise it won't work in scenarios when you power off and shortly after power on the circuit.
if you have a look at the page form the post above posted by Dana - in the first schematic the D1 diode is providing the needed discharging.
