Electronics => Beginners => Topic started by: K.primdahl.8270 on April 25, 2024, 08:54:12 pm
I'm puzzled by this resistor
Can anyone help please
1 Ohm.
It looks fine.
Have you measured it using a mutimeter?
https://www.digikey.in/en/resources/conversion-calculators/conversion-calculator-resistor-color-code?_gl=1 (https://www.digikey.in/en/resources/conversion-calculators/conversion-calculator-resistor-color-code?_gl=1)*1d14nck*_up*MQ..&gclid=EAIaIQobChMI-LiPqK_ihQMVaYbCCB22yA3REAAYASAAEgI6OPD_BwE
80 ohm 1% ?
is the second band grey or silver? i have never seen a resistor with 2nd silver band like this before...
just use a mulimeter...
blk-grey-blk-blk?
180?
blk-grey-blk-blk?
180?
The value wouldn't start with black unless the multiplier band was silver, and 180 would be BROWN grey black black. The grey/silver band has a sheen to it that differs from the pigment bands so is probably metallic silver rather than grey. Perhaps this color-balanced zoomed in view of it will help.
Its a tossup between:
Brown (1) Black (0) Black(0) Silver (/100) Black (???) = One ohm, with a mystery black final band (as black isn't a tolerance color)
and:
Brown (1) Black (0) Black(x1) Silver (10% Tol.) Black (250ppm TC) = Ten ohms, 10% tolerance 250ppm temperature coefficient.
and:
You are correct, of course. I had a brain fart there. I blame it on the flu I am undergoing.
if the second band from the nearest ist band is silver, it would be a 10ohm resistor. So what about the last black band? that depents from where you got that resistor. if its from a cheap chinese powersupply, that makes sense. i have seen a lot of things like this before...
or if the second band is grey, which makes the last(Tolerance band brown making it an 80 ohm resistor with 1% tolerance)
anyway check your resistor here:
