Author Topic: resonant circuit design  (Read 1703 times)
Offline mikicebe
  • Country: sk
« on: April 15, 2016, 05:03:55 pm »
Hey, Ive been watching some videos about resonant circuits and I came across one ( ) after which, I wondered whether the fact that inductor acts as a "capacitor" above its resonant frequency implies that at above these high frequencies inductors are used as "capacitors" and vice versa?
Thanks,
Offline albert22
Re: resonant circuit design
« Reply #1 on: April 15, 2016, 09:22:51 pm »
No. those are undesirable effects that limit the frequency of operation of inductors, capacitors and also resistors. A capacitor may become inductive above the auto resonance frequency but is not usable as an inductor. And vice versa.
Offline CatalinaWOW
« Reply #2 on: April 15, 2016, 09:39:10 pm »
Or to put it another way, yes they could be used that way if you could live with having them behave in their normal fashion at below resonant frequencies and with their relatively poor performance at frequencies above resonance.  No one I know has thought of an application that puts that to work.  It would greatly complicate design and analysis.
Much of electronics design is arranging things so that you don't have to worry too much about these things.
Offline uncle_bob
« Reply #3 on: April 16, 2016, 12:34:27 am »
Thanks,
Hi
One way of looking at things:
As frequency goes up, "capacitors" let signals through. In one respect, everything behaves like a capacitor. Crank the frequency up far enough and you can put "signals" through a brick wall. Crank it up some more and a steel wall becomes "transparent". In that respect, the fact that all electronic components are dominated by capacitance at higher frequencies than they were intended for is not to crazy.
Bob
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: April 16, 2016, 01:04:32 am »
"Used as" implies intent and purpose; usually, this is neither the intent nor purpose, and the capacity of an inductor, or the inductance of a capacitor, is an undesirable (yet unavoidable and inevitable) parasitic property of the component.
There are, in fact, situations where these aspects can be harnessed for benefit, but it's usually a very special-purpose thing.  For example, almost no one puts these parameters in their datasheets, and they're subject to change anyway.  Customized geometry, with these parameters under control, can be quite handy at times.
A distributed transmission line structure is arguably such an example: a transmission line (terminated into an unmatched impedance) exhibits inductance and capacitance at alternate, periodic frequencies.
I would suggest learning about transmission lines.  They are the fundamental component, the only one that can truly be expressed by electromagnetism.  They aren't so hard to work with; if you're used to describing things in terms of chronological events, nothing else is simpler!
Pure capacitance and inductance (lumped elements) are nonphysical: an abstract circuit diagram (net list, as SPICE calls it) has no representation of the speed of light, and the entire circuit reacts instantly to any given stimulus.  It is a useful fiction, which we use only because it results in simple polynomial equations.  We inevitably fall into the trap of forgetting the underlying truth, and believing in them directly instead.  At which point we must add hacks to our models (parasitics) to make them useful again, and we jolt ourselves awake just a little from our daydreaming.
In principle, it takes an infinite number of capacitors and inductors to model a real component; fortunately, as engineers, we know when enough is enough, so that it's usually quite reasonable to produce a lumped-element approximation.  The challenge is knowing to identify transmission line structures, and how to convert them into RLC equivalents suitable for the circuit.
Seven Transistor Labs, LLC
Offline TimFox
« Reply #5 on: April 16, 2016, 12:49:35 pm »
In relatively narrow-band RF applications, capacitors are sometimes used near their self-resonant frequency as very low impedance bypasses or similar, but that must be done carefully since they will be very different away from that frequency.
Offline mikicebe
  • Country: sk
« Reply #6 on: April 16, 2016, 10:14:31 pm »
Thanks everyone for your replies, it makes more sense now.
