Author Topic: Resonator Q factor and current  (Read 1462 times)
Offline fonographTopic starter
  • Country: at
« on: August 07, 2018, 08:58:40 pm »
If I have resonator with Q factor 10 with peak at 10 Hz,if I supply that resonator with 1 volt 1 amp 10 Hz sinewave from signal source,how high would the current inside that resonator get? Would the current be 1 amp or 10 amps?
« Last Edit: August 07, 2018, 09:11:06 pm by fonograph »
Offline bson
Re: Resonator Q factor and current
« Reply #1 on: August 07, 2018, 11:34:20 pm »
For a passive resonator, 1A.
Look up Kirchhoff's current law: what goes in must go out, and what goes out must come from somewhere.  Hence if it sits in a circuit the current inside it can't exceed the current at its terminals.
For an active resonator you need to include the supply current(s).
Online rfeecs
« Reply #2 on: August 08, 2018, 12:21:36 am »
No, for a parallel LC for example, the current circulating around the loop between L and C would be about Q times the current from the signal source, or 10 amps.
The following users thanked this post: fonograph
Online rfeecs
« Reply #3 on: August 08, 2018, 12:37:13 am »
Here's an example:
  • Country: at
« Reply #4 on: August 08, 2018, 07:04:59 am »
bson says 1 amp,rfeeces 10 amps...  so which one is true? I dont understand that circuit picture,but I think two of these probes say 10 while two say 1,so I guess thats proof that the circulating current inside resonator is the current of the signal source times the Q factor.
Online rfeecs
« Reply #5 on: August 08, 2018, 05:52:51 pm »
bson is correct that if you have 1A going into the input node of a resonator, you will have a total of 1A going out of that node.
But inside the resonator circuit, in the case of the parallel LC resonator, you can have higher currents.  Since the current through the L and C are 180 degrees out of phase, they can cancel.
Note that this is one example where you have higher current.  Different types of resonators will be different.  A series LC will have higher voltage across individual elements, but they will all have the same current.  A cavity resonator is different again.
  • Country: at
« Reply #6 on: August 08, 2018, 07:03:27 pm »
Today I tried to learn about parallel LC resonator and I saw its not really a resonator,but a band reject filter.Can it even resonate at resonance like serial resonator can?
Also the circulating currents inside resonator,you say they cancel inside,but how strong is their magnetic field? Would it be 1 amp magnetic field or 10 amp magnetic field?
Feel free to tell me about cavity resonator differences,I am interested in that too.
My goal is to make resonstor that will create strong magnetic field,I see the that serial LC resonator,a bandpass filter have the single frequency selectivity,but I read the voltage inside it gets higher,not the current,so the magnetic field doesnt get boosted by the extra strong circulating currents right? I read that parallel resonator gets high currents inside,but its band reject so cant resonate at single frequency.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: August 08, 2018, 07:19:45 pm »
You are missing one critical parameter: impedance.
A resonator is an RLC component, so you need three parameters to define them.  Any (linearly independent) combination will do, but the most important are R, L and C, and Zo, Fo and Q:
R = Zo * Q (for parallel, Zo / Q for series)
L = Zo / (2*pi*Fo)
C = 1 / (2*pi*Fo*Zo)
With this, you can fully describe the system and calculate its properties. :)
Seven Transistor Labs, LLC
