Author Topic: Reverse engineering and reimplementing a garden hose water timer  (Read 665 times)
Offline markitusTopic starter
Hey, first post here.. Long time Youtube channel follower! I know I shouldn't use the first post to ask for help but ...  I am having a hard time trying to understand how this water timer works |O
I bought a cheap chinesse water timer with the idea of reimplementing the electronics to add Lora Radio managment so I can turn or or off the valve from a large distance and all running on batteries.
I want to reuse the mechanical design of the product and create my own Arduino based PCB that fits on the plastic enclosure and I want also reuse the latching solenoid inside the device to manipulate the water flow.
While trying to reverse engineer the product I have seen that it's powered by 3xAAA batteries and uses 3.3v logic (I also want to use 3.3v to be as eficient as possible) , the solenoid needs at least 5v to turn or/off so it uses some kind of booster design to charge a 2200uf capacitor and then dump it's load with a very short pulse in one polarity or reversed polarity using a H-Bridge to open or close the valve.
809595-0
I came up with the following design while using my tester in continuity mode and following the traces on the original PCB but I can't really understand how it works (suposing I have done it right!)
809589-1
The product PCB's
809577-2
809583-3
How I supose it should work:
When the operation of the solenoid is required (it's very rare, maybe twice a day open/close cycle) the MCU operates a transistor to boost the voltage from the battries <5V to something between >7V and <10 and then charges the capacitor to this voltage for a few seconds then uses a second transistor to dump the capacitor load for a short period of time (150ms to 250ms) to a H-Bridge to operate the solenoid in one polarity or to the reversed polarity, then disconects the boster and the capacitor to preserve energy when no needed and sleeps till the next cycle is required.
A few questions:
1) Does the schematic makes any sense at all?
2) For my understanding it's using the inductor to boost the voltage, it's conected to the battery and ground with C11 and R14, since it's only needed to charge the capacitor and it's only required maybe only once a day it's not wasting lots of energy from the batteries?
3) What is R6 and D2 used for? to discharge the capacitor of residual energy? taking a look at the PCB D2 is a pin diode, why ?
« Last Edit: August 13, 2019, 09:24:14 am by markitus »
Offline radiolistener
Re: Reverse engineering and reimplementing a garden hose water timer
« Reply #1 on: August 13, 2019, 11:00:05 am »
it looks like Q3 make battery short circuit by MCU signal  :D
Online ledtester
« Reply #2 on: August 14, 2019, 02:21:20 am »
You may find this MOSFET bootstrapping design idea helpful:
https://youtu.be/zcQV_ZpK1W8?t=2m35s
The link starts at 2:35 into the video where it explains hi-side switching using a P-channel MOSFET. It then goes on to how to replace the P-channel MOSFET with an N-channel MOSFET using a bootstrapping circuit.
