Author Topic: Reversing an output's polarity using a microcontroller  (Read 2397 times)
Offline danners430Topic starter
  • Good at overcomplication
« on: September 06, 2018, 08:58:44 pm »
Hey guys,
I'm looking to control a set of points on a model railway using a microcontroller. The point motors I'm using are controlled by reversing the polarity between the two power supply terminals on the point motor. Obviously easy to do using a simple DPDT switch or a relay, but is there any other ways of achieving this?
The microcontroller runs off 5V, and the point motors off 15V.
Cheers guys
Sent from my ONEPLUS A3003 using Tapatalk
Online oPossum
Re: Reversing an output's polarity using a microcontroller
« Reply #1 on: September 06, 2018, 09:02:10 pm »
H bridge chips like the L293D. One L293D will do two motors.
http://www.ti.com/lit/ds/symlink/l293.pdf
« Reply #2 on: September 06, 2018, 09:11:22 pm »
That looks sensible :-) never noticed these before! I'm guessing two things from that datasheet, firstly that they're voltage and not current driven, so the input pins can be connected directly to the MCU output, and secondly that they could also be used to drive two lead bi-colour LEDs (overkill, I know)?
Online oPossum
« Reply #3 on: September 06, 2018, 09:16:02 pm »
Yes and yes.
« Reply #4 on: September 06, 2018, 09:16:38 pm »
Perfect - many thanks :D
Yes and yes.
Offline tooki
« Reply #5 on: September 06, 2018, 09:21:25 pm »
Can't one do that for bicolor LEDs just by controlling the pin modes? Isn't that what charlieplexing is based on?
A bit of googling shows it really is as simple as connecting it (with current limiting resistor) between two output pins and alternating which pin is high and which is low. So one pin sources the current and the other sinks it.
https://electronics.stackexchange.com/questions/334952/control-color-of-bi-color-led-using-arduino
« Reply #6 on: September 06, 2018, 09:24:10 pm »
Aye, that's the obvious solution... However I'm working with umpteen of said LEDs, and I have a limit of 70mA output current for the entire MCU, which will really only power 3 at a time... Hence I need a way of powering them externally, using the MCU just as the switch
Offline Zero999
  • 0999
The following users thanked this post: oPossum
Offline tooki
« Reply #8 on: September 07, 2018, 09:43:26 am »
Have you considered using addressable LEDs instead? That'd be a lot cheaper than h-bridge IC's, I suspect…
« Reply #9 on: September 07, 2018, 09:55:21 am »
I could certainly look into them... Never worked with them before, but always open to new discoveries :-) cheers for the tip!
Offline tooki
« Reply #10 on: September 07, 2018, 10:33:39 am »
They're what Adafruit brands "neopixels", FYI, so lots of how-to's refer to them as that. The actual model number of the most common type is the WS2812B. They're pretty awesome. They daisy-chain (forming a physically gigantic shift register), and with the third-party arduino libraries for them, you pretty much just say "LED #[position in the chain], change to [RGB value]" and it does it. The LED itself then does the dimming/color blending on its own, with no further CPU usage, even.
