Author Topic: Trying to find a connector and need your help  (Read 767 times)
Offline RandomUser2025Topic starter
  • Country: il
« on: March 06, 2025, 07:56:46 pm »
Hi everyone!
I'm looking for some help looking for a connector I've been searching for...
I got the male type of the connector and I need to find the female port that would fit it, the connector is about 7mm long and 2mm wide, it got 17*2 pins, a picture of it will be added to this post,
Hope you can help me find it, thanks in advance!
Offline benj38
Re: Trying to find a connector and need your help
« Reply #1 on: March 06, 2025, 10:45:35 pm »
What is the exact spacing between the center of one pin to the next pin in the same row?
  • Country: il
« Reply #2 on: March 07, 2025, 01:51:38 pm »
First of all thanks for your answer,
Here's a chart of the sizes
Offline benj38
« Reply #3 on: March 07, 2025, 04:03:24 pm »
The critical measurement we are still missing is between pin centers of two adjacent pins on the same row of 17 pins. it looks from the other measurements like it is 0.4mm, but please verify (easiest I guess is to measure the distance between the center of one pin and a pin ten positions ahead in the row and see if it is 4mm).
These are often called mezzanine connectors, and something like Panasonic AXT334124 may be what you need, but you should look at the different dimensions in the datasheet and compare them to your connector to verify!
https://www.lcsc.com/datasheet/lcsc_datasheet_2410311221_PANASONIC-AXT334124_C3652500.pdf
« Last Edit: March 07, 2025, 04:29:04 pm by benj38 »
  • Country: il
« Reply #4 on: March 07, 2025, 07:44:26 pm »
It does seem like you're right, thank you!
I'll try getting one and update if needed, I really appreciate your help :D
Offline wraper
  • Country: lv
« Reply #5 on: March 07, 2025, 08:15:34 pm »
Connector height is absolutely needed to figure out what it is.
Offline Jwillis
« Reply #6 on: March 07, 2025, 08:37:58 pm »
The width of the Panasonic is to wide compared to your measurements. Even Molex slimstack is to wide. Try KYOCERA AVX 34 Position. https://www.mouser.ca/datasheet/2/40/5804-3011047.pdf.  Your picture looks like the plug.
Offline u666sa
  • Miami, FL
    • Codernov Electronics Repair
« Reply #7 on: March 07, 2025, 10:31:46 pm »
This is a 34 pin fpc connector  :horse:
https://www.aliexpress.us/item/3256806871530839.html
https://www.aliexpress.us/item/3256806284898288.html
So long as connector length is similar within mm, you should be able to desolder the old one, and solder the new one, and then use the corresponding motherboard receptor.
As far as spacing goes and height, that's only important if you want the same exact one. But it don't have to be the same exact one. You get the one with same over-all length, so you can solder it on.  :-+
You swipe pins with flux and apply rose's metal. Then you blow from below with 220C and take off the connector. Clean contacts with solder wick. Apply solder, paste if you want, and flux, and solder in the new connector. Idea is not to destroy the original connector and save it for possible later use.
« Last Edit: March 07, 2025, 10:37:23 pm by u666sa »
