Author Topic: 0603 package used instead of a jumper wire?  (Read 5867 times)
Offline Falcon69Topic starter
« on: September 16, 2014, 07:44:17 pm »
I am running into a problem with a circuit I am working on.  Things are just way to tight on this board. Is it okay to use an 0603 instead of a jumper wire?  I don't have space underneath to connect the ground plane of two connected vias that are connected to a component on the top layer. But, I may be able to run a 0603 across a trace on the top plane, then connect it to the ground of another component to connect that ground plane.
I found some 0ohm resistors, would those work as a jumper?
Offline Pedram
  • Country: ir
Re: 0603 package used instead of a jumper wire?
« Reply #1 on: September 16, 2014, 07:58:26 pm »
yes it works. but not for high frequency signals or very high impedance analog traces.
also note that they cannot handle much current.  ~1A typical.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: September 16, 2014, 08:14:27 pm »
I believe that that is exactly what 0 ohm resistors are for and for what they will cost much cheaper to implement as they can be assembled with the rest of the board in a pick and place machine instead of being hand soldered jumpers later.
« Reply #3 on: September 16, 2014, 08:31:20 pm »
OKay, sounds good.
I have two more traces to do, and the might just be the fix!
And yes, I know about the power rating.  0603 1/4 resistors should be fine.
Are you saying, because they are 0 ohm, they can actually handle around 1A?
Offline Chris_PL
« Reply #4 on: September 16, 2014, 08:58:27 pm »
They can handle *only* around 1A, because they *are not 0 ohm* in reality (in fact, nothing is, but this is a topic for a PhD thesis). In terms of current handling and so on, a jumper wire with 0603 diameter will do better of course.
Safety note: Don't put all your enriched uranium hexafluoride in one bucket. Use at least two or three buckets and keep them in separate corners of the room. This will prevent the premature build-up of a critical mass.  ;)
Offline Simon
  • Global Moderator
« Reply #5 on: September 16, 2014, 08:59:47 pm »
I don't know what they are made of but erm 0 ohm means no voltage drop so no power loss, of course they are not really 0 ohm and have a small resistance just like wire. 1A sounds right
« Reply #6 on: September 16, 2014, 09:10:09 pm »
cool, sounds easy enough.
thanks guys
Offline Monkeh
« Reply #7 on: September 16, 2014, 09:14:40 pm »
Depends on the jumper. 'jumper' versions of standard resistors are a bit meh. Dedicated jumpers, well: http://rohmfs.rohm.com/en/products/databook/datasheet/passive/resistor/chip_resistor/pmr_jumper.pdf
« Last Edit: September 16, 2014, 09:37:59 pm by Monkeh »
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #8 on: September 16, 2014, 09:40:41 pm »
Just make sure you use 1% ones  ;D
Day Job: Mostly LEDs
« Reply #9 on: September 16, 2014, 09:46:45 pm »
good point.  :-+
Offline w2aew
    • My YouTube Channel
« Reply #10 on: September 16, 2014, 09:50:45 pm »
FAE for Tektronix
Offline ConKbot
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #12 on: September 17, 2014, 02:15:17 am »
Mouser listing is wrong. The data sheet says 5% tolerance.
But what is 5% of 0?
A piece of 24ga solid copper .06 long is .000128 Ohms so 5% would be +/- .000006 Ohm
« Reply #13 on: September 17, 2014, 02:17:00 am »
Is that basically what is inside those zero ohm resistors?  Just a piece of copper wire?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #14 on: September 17, 2014, 08:27:35 am »
No, they are manufactured with the same metallic paste as regular resistors, except it's put on thicker and, obviously, not laser trimmed to an exact value.  You can use them for small resistances if you want, but don't expect great tolerance.
Seven Transistor Labs, LLC
Offline lilmantis
« Reply #15 on: September 22, 2014, 02:36:50 pm »
I've seen these with up to 75-100 mOhms
Offline idpromnut
« Reply #16 on: September 22, 2014, 03:00:00 pm »
If it's a layout issue (i.e. things are getting tight etc space-wise), this is typically a good time to stop and take a step back and ask yourself where the issue really is: perhaps the placement of your components on the board can be re-arranged to not have to use the jumpers (especially for a ground plane). If that doesn't work, go back and check your schematic for optimizations that you can make there which will help you lay out the board.
I'm sure others here can throw out a few words of wisdom in terms of tricks to use to help ease the layout step of a new design. Try to lay out the board without jumpers!  :-+
