Hi, I'm designing a receiver for electric skateboard using RFM69HCW, the requirement is to have a ceramic SMD antenna but also have the ability to somehow change/switch it to U.FL(pigtail?) coaxial connector, so off the shelf external antenna can be used instead if the signal with ceramic antenna won't be good enough.
I've seen some construction(see the pic) where track is split into two and placing small ceramic SMD capacitor will switch to either antenna.
Is it a good way to do it?
What capacitor should I use?
Is that capacitor going to descrease the range?
I'm a complete noob when it's about RF and I don't even know what keywords to use to google my answers regarding this so that's why I ask you.
The frequency is 433MHz
Thanks!
