Hi everyone.
I am about to get into my first solo build and the plan is to make a strobe light by way of a 555 timer and some RGB LED's(3-5mm). I plan on using a 12V supply and a bunch of potentiometers.
1. How do I achieve a 50% duty-cycle?
My calculations tell me that R1 must be 0, so that R2 can be a pot which I vary to change the speed of the strobe.
2.a) How am I to best wire my LED's?
My idea was to put them in parallel with about 6 LED's per row in 4 columns.
2. b) How am I to control color best?
I was planning on having all the separate color probes together for each color then vary the current in those by way of potentiometer and manually make colors from those.
3. Am I using the right type of LED?
I know I could be using an addressable LED strip to make my life better but I do not own any microprocessors just yet. Apart from those, would high power RGB LED's be better for such a build? My fear is all about the heat dissipation as I would not like to have anything get super hot. (The plan is to keep it as cheap as possible till convinced otherwise so I am avoiding heat sinks)
4. Is using a transistor better that leaving my output as the LED panel?
I plan on using a transistor because my 555 output voltage is not too constant but by using an inverter logic layout, I can have my (perfect) 12V supply to the LED panel to help with the consistency of the brightness and action.
