Author Topic: Floppy drives and their right angle header with reversed key  (Read 139 times)
Offline fabiodl
« on: April 16, 2021, 04:11:14 am »
Many floppy drives have a shrouded 34 pin connector with the notch on the bottom, as by attached picture.
However, all shrouded right angle 34 pin headers I find have the notch on the top
Have a look here for example.
Do you know any source / what I should look for?
« Last Edit: April 16, 2021, 09:30:54 am by fabiodl »
Offline fabiodl
Re: Floppy drives and right angle header with reversed key
« Reply #1 on: April 16, 2021, 09:28:09 am »
Some drives have the notch in the PCB
but all the others seem to have that bottom notch on the shroud
« Last Edit: April 16, 2021, 09:30:18 am by fabiodl »
