Author Topic: How to choose a resistor?  (Read 881 times)
Offline redgear
« on: November 01, 2019, 10:37:46 am »
I am trying to recreate a reference circuit that I found online. The circuit has a BOM which specifies the resistances to use.
I know the value of the resistor, case code and the tolerance. I assume case code won't matter much as long as I can solder the components properly(correct me if I am wrong). There is no info about the power rating, temperature coefficient and voltage rating.
How do I choose a resistor without these?
Thanks
« Last Edit: November 01, 2019, 11:06:40 am by redgear »
Online tggzzz
Re: How to choose a resistor?
« Reply #1 on: November 01, 2019, 10:55:28 am »
You need to understand how the circuit works. A well-designed circuit will minimise the dependencies, but can't eliminate them.
If you can't understand the (analogue?) circuit, you could simulate with, say, LTSpice. You could manually tweak component values, or set it up to do monte-carlo simulations.
Offline redgear
« Reply #2 on: November 01, 2019, 11:21:10 am »
Thanks.
The resistors are directly connected to the pins of the IC. I only have access to the block diagram of the IC. I don't think I simulate it. Can I? The Datasheet is in Chinese which makes things more difficult. I am attaching the circuit below for reference.
[attachimg=1]
EDIT: The power traces are thicker that the others, how do I determine the thickness that I would require?
« Last Edit: November 01, 2019, 11:40:31 am by redgear »
Online tggzzz
« Reply #3 on: November 01, 2019, 11:46:33 am »
Most of those resistors maximum possible power dissipation can be easily calculated: V2/R, where R is the supply voltage. For R2/R7, reduce V by one LED forward voltage drop.
RNTC is interesting; NTC may mean negative temperature coefficient, which implies a thermistor. Unfortunately thermistors are made with differing tempcos, so the best bet would be one with a tempco in the middle of the  possible values.
Google can be useful when looking at foreign language datasheets.
Offline redgear
« Reply #4 on: November 02, 2019, 06:48:07 am »
Do you mean V is the supply voltage?
Yep, RNTC is a thermistor and they are 100K @ 25deg with a material constant of 4200
I have been using Google Translate. But a lot of information is given as a image and I am not able to translate them.
Online tggzzz
« Reply #5 on: November 02, 2019, 08:37:34 am »
Yes, V :(
Given that information, use DigiKey to find a thermistor.
Bummer.
The following users thanked this post: redgear
Online PA0PBZ
« Reply #6 on: November 02, 2019, 08:57:52 am »
Try the Google translate app for IOS/Android, it translates using the camera. I tried it on the text in the diagram and it works fine.
Offline Gallardo
  • Country: cn
« Reply #7 on: November 08, 2019, 05:19:31 am »
Hope it helps you ;)
R1 to VOUT1, R1 to VOUT2, R1 to VBUS, R1 to VIN four lines need to be separated from the R1 pad, the current path of the four lines can not have any coincidence, otherwise it will affect the multi-port change single port is automatic recovery fast charge function .
Note that the power path traces need to be as short and wide as possible, and the line width needs to be at least 80 mils.
When the NTC function is not used, R12 is replaced with 51KOhm, and RNTC does not need to be installed.
Offline Gallardo
  • Country: cn
« Reply #8 on: November 08, 2019, 05:31:12 am »
for reference
Offline redgear
« Reply #9 on: November 08, 2019, 10:54:15 am »
Thanks.
But from the connections shown R1 is not connected to either of VIN, BUS, VOUT1 or VOUT2.  :-//
I still have few more questions on the same project. Would be great if you can help me.
I have created a new thread for the same.
« Last Edit: November 08, 2019, 11:06:54 am by redgear »
