Author Topic: Differential amplifier IC  (Read 341 times)
Offline mitrynicolae
« on: April 30, 2019, 09:08:19 am »
Hello everyone,
Does anybody know any IC that matches all the following requirements:
- it is a differential amplifier
- it has a 0.1 gain
- can operate on a single 5V power supply
- AND is rail to rail
For example AD628A meet all the above conditions, except is not rail to rail.
Thanks!
« Last Edit: April 30, 2019, 09:11:17 am by mitrynicolae »
Offline pwlps
Re: Differential amplifier IC
« Reply #1 on: April 30, 2019, 09:17:12 am »
You can assemble your own 0.1 gain differential amplifier using an opamp and resistances.
The low voltage family TLV277x  (x=0,1 etc) is said to be rail-to rail output.
