Author Topic: rigol ds1054z, only 500 Msa/s when only 1 channel active, is it normal ?  (Read 1610 times)
Offline blandiantTopic starter
i just got a rigol ds1054z with all the options.
When all the channel are turned off, it is writen on the screen that the sample rate is 1 Gsa/s and the memory depth is 24Mpts but as soon as i activate one channel(no matter which one) it is written that the sample rate is 500Msa/s and the memory depth is 12Mpts, and i can't use a higher sample rate/memory depth than this.
Is it normal ? (i attach 2 pictures to show you)
Thank you
« Last Edit: August 05, 2018, 11:56:10 am by blandiant »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
yes its normal when your trigger channel is not the one shown.
Online Zero999
  • 0999
It's because it achieves 1Gsa/s by interleaving multiple ADCs (I can't remember how many, look it up if you're interested) with a lower bandwidth. With only one channel activated, all the ADCs become allocated to that single channel, so the sample rate can be higher, than with two channels activated. I can't remember whether activating three or more channels limits the sample rate even further, but someone else here will know.
« Last Edit: August 05, 2018, 02:01:00 pm by Hero999 »
  • Country: my
yes, any active channels, including triggering channel, even if not visible, more than 2 = 250MS/s
Offline Adrian_Arg.
  • Country: ar
1 active channel 1 Gsa / s
2 active channels 500 Msa / s
with 3 and 4 activated channels 250 Mgs / s
I do not know if it influences that I have it released as a DS1104Z
Online Zero999
  • 0999
Right, so there are four ADCs, each capable of 250Msa/s, which can be interleaved to get 1Gsa/s, 500Msa/s or 250Msa/s, depending on whether one, two or three or more channels are required.
