Author Topic: Strange Behavior of brand new BRYMEN BM869S when checking TRIAC  (Read 594 times)
Offline KalulukaTopic starter
Hi!
Today I discovered strange (at least for me, but maybe I’m wrong) phenomenon, when i was checking BTA16-600B Triac with Brand new Brymen BM869S: when in diode mode and Black Lead (Common) at Anode1 and Red Lead at Gate it shows  0.1804 Volt’s (like Zener Diode), any other DMM shows around (Give or Take) 0.4500 Volt’s.
Maybe I do no’t understand something right and someone has explanation for this?
If I check power Rectifier (Diode) it shows normal value.
Please Check attached pictures
P.S. All the measurements are taken with same Leads on all DMM and with same Triac.
Regards,
« Last Edit: April 25, 2022, 04:06:53 am by Kaluluka »
Re: Strange Behavior of brand new BRYMEN BM869S when checking TRIAC
« Reply #1 on: April 25, 2022, 04:09:24 am »
More Pictures:
Offline jonpaul
« Reply #2 on: April 25, 2022, 08:35:55 am »
Normal: Check the triac internal form and specs.
Gate and anode do NO behave like an ordinary diode.
Use another better  brand of meter
Jon
Jean-Paul  the Internet Dinosaur
Offline wraper
  • Country: lv
« Reply #3 on: April 25, 2022, 08:45:32 am »
G-A1 acts more like a resistor, not like a diode. Brymen probably uses lower current in diode mode, hence you get lower voltage drop reading.
« Reply #4 on: April 26, 2022, 03:26:15 am »
THANKS for all the Reply's!
I will test this further.....
Regards,
