It depends on your use case. For temporary stuff I use the cheap "One Hung Low" stuff, but they really are garbage (don't crimp as securely, are super thin and flexible, are much much more likely to snap off or fail). For anything permanent or important (like mains level voltage) I usually get Anchor brand or equivalent quality. They are eye-wateringly expensive, but they are far and away better quality plus they are corrosion resistant since they are made for marine applications. TE makes some great stuff too, check out their "Diamond Grip" line. I believe it is mil-spec.
