I am trying to learn how I determine max allowable power supply ripple for flawless functioning of a component, out from a datasheet, because I can't seem to find out.
+FriedMule
As some of the other members have indicated, afraid you are asking the wrong question here. What you need to determine is what noise plus ripple (N+R) does my particular application require.
For example, if you were just turning a 12V relay on, a 12V supply line with a N+R of 2V would be acceptable.
But if you were building an an audio preamplifier using an operational amplifier you may need a 12V supply line with no more than 100uV N+R.
There is one component where the ripple voltage is fundamentally important. The ripple voltage across a capacitor creates a ripple current through the capacitor. The ripple current causes internal heating and if the ripple current rating of a capacitor is exceeded the capacitor can be damaged. This aspect is most important in the case of power supply reservoir capacitors.
In electronic engineering there are basic design rules (BDR), which everybody uses. For example, to decouple an opamp you would use 100nF low ESR capacitors. You do not generally work out what value capacitor to use because in most cases 100nF will be fine.
Likewise with power supplies. In most cases a mains transformer-bridge rectifier- reservoir capacitor raw supply is adequate for the input to a three terminal regulator, like the LM317 or LT1086. And providing that you use the components specified in the datasheet, you will have a stabilized supply line more than adequate for most circuits, especially if you add the extra capacitors to increase the regulators performance as shown in the data sheet.
Typically, the output supply line from a medium price linear bench power supply would have a maximum N&R of 10mV, so that gives you an idea of the amount of N&R that is generally acceptable.
If you do have a circuit that requires very low N&R supply lines, an often used approach is to fit another low noise regulator running from the supply line of the first regulator. Also local decoupling is used.
There are many factors that affect N&R: layout, especially the 0V line, component type, screening ...
That ends the cracker barrel advice. But I hope you can move on and enjoy your electronics without worrying anymore about ripple.
