An old but readily available hobbyist friendly DC-DC converter IC is the
MC34063A.
Also see OnSemi's
AN920 which goes into its theory of operation and design calculations in far more detail, and has many more example circuits.
It supports switching currents of up to 1.5A so depending on the duty cycle you can easily get several hundred mA of output current. Its cheap and readily available in a DIP-8 through hole package. Its low switching frequency (<100 kHz, typ ~25 kHz, but varies with load as it cycle skips to regulate) means it tolerates poor layout and even solderless breadboarding with few issues. It can be used in boost, buck and inverting buck-boost applications with or without an external switching transistor. Its switching transistor and supply voltage has an abs. max rating of 40V, so it can boost to over 30V without a transformer or voltage doubler, and work with over 30V DC in.
The downsides are the low switching frequency which requires far bigger and more expensive inductors and capacitors vs a modern switching DC-DC IC operating at high hundreds of kHz to low MHz, and the high current sense threshold (typ. 300 mV), so high I
2R losses in the sense resistor, and bipolar output stage which inevitably has much higher losses (so lower efficiency) than a MOSFET. Also its 'low' standby current is max. 4mA and typically in the 2.5 - 2.8 mA region so its unsuitable for most battery powered applications without an upstream power switch.
