Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Roland Cube 40 transistor help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Roland Cube 40 transistor help (Read 226 times)
Supernaut
Newbie
Country:
on:
March 09, 2024, 04:37:06 pm »
Hoping to get some insight from users on here regarding some components I need to track down for my Roland Cube 40. Im looking for replacements for 2SD667C, 2SD666C and 2SB647C although when i try track down data sheets some don't include the letter "C" at the end of the part number. These components are obsolete so it also suggests some modern equivalents too but I cant find data sheets for my existing parts so I don't know if they compare.
Ive tried to include two pictures but they don't seem to show when I click preview post, ,unsure if they will appear.
https://pdf1.alldatasheet.com/datasheet-pdf/view/63045/HITACHI/2SD667.html
https://www.alldatasheet.com/view_datasheet.jsp?Searchword=2SD666C
https://pdf1.alldatasheet.com/datasheet-pdf/view/62848/HITACHI/2SB647A.html
Logged
Kim Christensen
Super Contributor
Country:
Re: Roland Cube 40 transistor help
Reply #1 on:
March 09, 2024, 04:53:00 pm »
The B, C, or D suffix is the transistor Beta range. Otherwise they are the same:
Logged
Supernaut
CaptDon
Super Contributor
Country:
Reply #2 on:
March 09, 2024, 05:19:41 pm »
About 5 years back I was able to find exact part number replacements from Toshiba. Carver used similar transistors in the TFM-22 and many other amplifiers. They would develop leakage when they got warm and the idle bias on the outputs would go nuts.
Logged
Supernaut
Supernaut
Newbie
Country:
Reply #3 on:
March 09, 2024, 06:00:49 pm »
Thank you both for the replies, Im fairly new to silicon components so sometimes I find it difficult to compare information on data sheets without becoming snow-blind. On some items Ive seen one letter change and the values on the data sheet change drastically so I was uncertain on what to do here.
Should hopefully have the amp repaired sometime next week
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
