Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
rom 23C128 TO 27C128 ADAPTER
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: rom 23C128 TO 27C128 ADAPTER (Read 989 times)
Daxxin
Regular Contributor
on:
January 13, 2019, 08:06:10 am »
Any schematic about this adapter?
Logged
johnkenyon
Regular Contributor
Country:
Re: rom 23C128 TO 27C128 ADAPTER
Reply #1 on:
January 13, 2019, 02:47:39 pm »
Might be an idea to tell us where/how you are planning to use the adaptor.
Note that the chip select/enable(s) on 23C128 were defined active high or low along with the ROM mask, and can have more than one chip select. (For example:
http://hardware.speccy.org/datasheet/23c128.pdf
One example is the ZX Spectrum - which effectively had two active low chip selects plus output enable - in this case it is better to mod the PCB to synthesise a nCE signal using a pair of diodes, and use the existing socket. (See:
https://spectrumforeveryone.com/technical/fitting-eprom-48k-spectrum/
Last Edit: January 13, 2019, 02:55:24 pm by johnkenyon
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
