I totally deny you. may be my specification may be to high for a beginner and Now i feel There is no need to built a circuit which can deliver 100W of power. Neither i could go for LT3080 which could control both voltage and Control regulation with dissipation of Nearly 30W. This is what i would understand from this forum.I cannot analyse big circuit. I donot know where to start my analysis.
You've been told, gently assisted, repeatedly mentioned, yet, you are stubbornly deny any good intentions and helps offered, and keep spamming again and again ... oh ... again.
Here i could not get the component which we have discussed in this thread. What ever is available here i could use it.I could not order from online website because i am student of electronic engineering. my economy wont allow me.
Yep, again .. you've been told, explained and "sympathized" on the limitation of common Indian's budget limitation, with circuit designs that of course limited, but fit into your budget and component availability, and very likely available to you at your country as they're common jellybean components, yet, you ignored and stubbornly create another
same identical request at new thread ... again.. again.. and again.
.. oh ... forgot ... again.
A simple LM723 cost ten rupee which is affordable my me. So i was searching for circuit with LM723. This is the reason for those those thread.
Again ... geezz... I'm tired typing this word, you've been assisted, gently informed (as people were aware of price sensitive for Indians and worry that might offend you) for "alternative" circuits that don't use 723, but still ...
... you keep spamming with new thread asking to people to spoon feed you in "designing" a 723 based pcu .. oh .. again..again ... and again.
I respect every one in this forum, Sorry If i hurted you all. Thank you all .
Whatever, just DO NOT make a new same new discussion thread, or worst re-register a new nick and launch the same nagging again.
Show appreciation for those generous people who helped you, don't just ignore and abandon the ongoing thread when every times you don't like it, and create another identical thread ... again.
