Hi Everyone,
That breadboard meter is awesome, would be a nice addition to have.
Very nice job on that - badass!
The board layout looks top notch and your soldering is impeccable, not to mention it's a cool little device. Congrats!
Good job! very nice indeed.
I appreciate the positive feedback - I got the idea when I saw one of those power supply adapters on eBay and thought I would sure love to know if a change I make on the breadboard results in an overcurrent (short) situation right when I do it.
Seriously your first SMD soldering? I made few, but still far away from your skills.
You should have seen my first PTH soldering - It was awful! I was trying to solder a header onto a 2x7 100mil LCD header and getting solder bridges! The radio shack iron I was using sure wasn't helping though.
Can you post the schematic of this?
Sure:
Here are all the project files including source code and a parts list.
http://home.earthlink.net/~alank2/bbmeter/bbmeter.zipWhat is the Voltage/Current supply range and a measurement range?
I do most of my projects at 5V, so normally a single 5V jack supplies the meter and the breadboard. You can disconnect the two and power the meter part separately and the power the breadboard with a different voltage - see the schematic. I think the voltage can go up to 20V with the voltage divider/2.5V reference I am using.
Thanks,
Alan
