Author Topic: Über noob question  (Read 946 times)
Offline per4manzTopic starter
Über noob question
« on: March 09, 2019, 01:27:07 am »
I am working on a Macbook Pro board and see "xw7100" listed on the boardview near the backlight driver. Boardview & schematic indicates pin 1 is "GND_LCDBKLT_SGND" and pin 2 is simply ground. However, I do not see anything on the board, not even pads.
Told you - über noob question as I am pretty sure that nothing is supposed to be there (and there isn't), but am certainly looking to learn more and understand exactly what that is or isn't.
Thanks.
Offline Shock
Re: Über noob question
« Reply #1 on: March 09, 2019, 08:51:30 am »
Sounds like a surface mount link between two traces. If in doubt use your multimeter and test resistance between anything directly connected to those two corresponding labels (on the schematic) and to a ground. But when you find inconsistencies double check you are looking at the right schematic or revision.
We have a repair section on the forums, if you have repair specific questions post there and include or link to the specific model, schematic and boardview etc.
Offline ebastler
« Reply #2 on: March 09, 2019, 09:56:14 am »
A photo would have been helpful, but lacking that, I agree with Shock: It is probably meant for an optional SMD component to connect the two separate ground nets, either a direct link or possibly an inductor? Maybe they were not quite sure what would be required for signal/noise or EMC reasons, and ended up deciding that they could get away without the part.
« Reply #3 on: March 09, 2019, 05:12:04 pm »
Appreciate the answer guys. I will certainly repost in the repair section with more details.
