Author Topic: S-Parameters De-embedding using matlab/frequency vector problems  (Read 1326 times)
Offline RFbeginnerTopic starter
hello,
I'm trying to deembed a DUT that has two connectors as fixtures i have the SP of the measured DUT+Fixture and the SP of the connectors,
 here is some of the code;
S_measured = sparameters('S2P-Hyb-41.s2p');
S_fixture = sparameters('DeEmbeddedFixture.s2p');
freq = S_measured.Frequencies;
%% DUT De-embedding
S_DUT = deembedsparams(S_measured,S_fixture,S_fixture);
it's the same connector but i used it twice so...
BUT while running the code this shows up regarding the DUT Deembedding section:
"All sparameter objects must use the same frequency vector and the same impedance value."
both objects do have the frequencies
can anyone help me solve this ? i'm new to matlab and deembedding
both files have a frequency range from 1.5 to 3.5GHz and both are on 50Ohm adjusted so i don't quite get it
