Thanks for the input, but I think everyone agrees that a) the base-emitter is forward biased, and b) the base-collector is reverse bias. NPN or PNP, doesn't matter. It's specifically the signal input (reverse) that I don't understand. The input is connected to the base, the emitter-base DC source, and ground. Somehow this means that the input is across base-collector which is reverse bias. Why can't I say the input is across base-emitter? It's right there, look it at, even sharing a nice little DC source with the base.
Not really.
See 6-13 and 6-14 in your drawing.
Note that the signal source is connected to the base AND to ground. The emitter is connected to ground through a resistor. Since the base emitter is forward biased it only has a small voltage drop, like 0.7v. With no signal input the emitter could have a very low voltage (unless biased to 1/2 Vcc). The collector has a constant voltage applied to it, so the voltage between the base and collector could be 12 volts.
As the signal changes, the current through the base emitter changes, and that changes the current through the collector to emitter, and that means the emitter voltage changes. For a positive input change the current through the base emitter rises, and the current through the collector to emitter rises, and thus the emitter voltage rises.
This is also called a Voltage Follower because the emitter voltage approximately follows the input signal voltage.
If the input signal was connected to the collector, there would be a huge current into the base emitter, which would probably blow out the transistor or at least cause it to saturate, and that would even be with no signal input at all. The impedance of the signal source would cause a large input current through the base emitter which would not work very well at all.
The main reason for the transistor action is the current through the base emitter (or also viewed as the voltage across the base emitter). The voltage across the collector base does not matter as much by a long shot, so changing the collector to base voltage would make hardly a difference on the output voltage. There is a small change that would accompany a forced change in collector to base voltage (see the Early Effect), but it would not be anything like amplification if you did that as it is a minor effect. Thus it would not make too much sense to try to purposely vary the collector to base voltage if you wanted some decent amplification.
