I'm working on a device that generates low frequency triangle and square waves. The final output is amplified by a non-inverting opamp circuit with a gain of about 5. The problem I'm having is the square wave output is not symmetrical, it sags toward zero at both the positive and negative pole. The input into the opamp looks fine, as illustrated by the screen capture from my scope. Yellow is the output, blue the input into the output circuit.
What would be causing this and how can I remedy it? BTW the triangle output is fine.
Schematic of output circuit attached.
