Author Topic: Sallen Key Filters for Audio EQ  (Read 1833 times)
Offline ConorK2567Topic starter
« on: December 18, 2019, 05:38:10 pm »
Hi Guys,
I'm going to try make some sallen key filters for a university project with the hopes of making an EQ unit. I'm studying music technology and am a complete beginner with electronics so I have a few (stupid) questions.
1) Has anyone got any decent sources about the construction of/working with Sallen key filters that they would recommend?
2) I have chosen some component values in the link below to get a desired cutoff and Q. In your experience will these values work or should I aim for different values?
https://docs.google.com/spreadsheets/d/1lN3tLxwtOUL513ik1I3b4O2mQuzJMyJDHgwNR45Xji4/edit?usp=sharing
3) If I want to add a control for the frequency is that as simple as using a potentiometer for the resistors in the circuit?
4) When I have been looking at components I have seen things like 'power rating' (on pots) and "voltage rating" (on capacitors). What values should I be looking at for those in an audio circuit and how do I pick the correct one.
Thank you to anyone who reads this and a big thank you to anyone who replies
C
Online schmitt trigger
  • Country: mx
Re: Sallen Key Filters for Audio EQ
« Reply #1 on: December 18, 2019, 06:04:07 pm »
Analog Devices has many excellent opamp filter design tutorials.
https://wiki.analog.com/university/courses/tutorials/index#active_filters
To your question #3, you want to make a tunable bandpass filter? That is not as simple, and I don't think that Sallen Key is the correct topology.
Perhaps the better option would be a clock tunable (switched capacitor) device like the classic MF10
The following users thanked this post: ConorK2567
Online oPossum
« Reply #2 on: December 18, 2019, 07:45:26 pm »
Yes, you can adjust the frequency of a Sallen Key filter with a pot. This is common in active crossovers. One of the problems is that the ideal pot has reverse log taper. Those are usually a build to order part. Another problem is tracking between the gangs.
Most graphic equalizers use gyrators. That is a much simpler approach than using active filters.
A random circuit example... http://www.hobby-circuits.com/files/352/6-band-graphic-equalizer_orig.gif
Online David Hess
  • DavidH
« Reply #3 on: December 19, 2019, 01:18:54 am »
What kind of equalizer did you have in mind?  Graphic equalizers generally use a gyrator to synthesize the inductance for a bandpass filter for each section.
Small Signal Audio Design by Douglas Self has a chapter devoted to tone controls and the various types of equalizers.
  • Country: mx
« Reply #4 on: December 19, 2019, 04:41:03 pm »
Thanks for reminding me. I vaguely remembered a complication, but could not recall what it was.
Of course, it was the specialty pots.
« Reply #5 on: December 20, 2019, 04:37:29 pm »
Thanks so much to everyone who replied!
I have had a look at the sources you guys have mentioned briefly and they look like great resources - really helpful.
What a shame about the BPF - perhaps I will have to say that this is a limitation of it and show a better solution. I always thought it was just a matter of cascading a high and lowpass filter together though?
Am I being really stupid if I say that I could just wire a traditional logarithmic pot backwards ?
Is there a place where I can get some pots like that ? I have been using farnell and RS online so far.
My plan is to make a parametric EQ unit with the following filters:
High pass (Sallen Key)
Low Shelf (Baxendall style)
Band Pass (?)
High Shelf (Baxendall Style)
Low Pass (Sallen Key)
Thanks again
« Last Edit: December 20, 2019, 04:45:10 pm by ConorK2567 »
