Author Topic: Sourcing a small lcd screen  (Read 2021 times)
Offline carbon dude oxideTopic starter
« on: July 30, 2013, 12:43:30 pm »
Hello, i am having trouble sourcing some kind of lcd screen, it can be colour or just back and white but the only problem is that the physical size needs to be 27.5mm wide or slightly smaller and it needs to be between 35mm to 55mm long. Does anyone know any manufacturers which do this sort of size or a company tht can do custom sizes this small?
It does need to be as high of a dpi a possible as the screen (if possible) would have a small bar code accross the bottom.
Does anyone know anyher i could get something like this?
Everything Should Be Made as Simple as Possible, But Not Simpler
Offline David_AVD
Re: Sourcing a small lcd screen
« Reply #1 on: July 30, 2013, 10:05:10 pm »
Have you looked at the ePaper screens?  I got a 2.7" kit the other week (haven't had time to play yet), but I'm sure you can get much smaller ones.
« Reply #2 on: July 30, 2013, 10:22:04 pm »
They look almost perfect for the use i need XD tere thin require very little power (only consumes when changing) and displays the last image even when there is no power. I have had a quick glance on google and so far cant find one small enough but i shall have a look in the morning
Offline David_AVD
« Reply #3 on: July 30, 2013, 10:30:29 pm »
I got my demo kit from Glyn over here. They have a 1.44" version.  Not sure if that is small enough for your application.
