Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Same button for two circuits
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Same button for two circuits (Read 948 times)
hotter
Newbie
Country:
on:
February 06, 2019, 07:46:28 pm »
Hi, I have car mp3 player which I would like to integrate to my car stereo player/steering wheel buttons. So basically I want to reuse same buttons from car to switch songs on mp3 player.
So my question is can I wire different circuit to a button which is used by cars circuit? It could impact another circuit correct? what are my options here if I want to use same button for 2 circuits?
Last Edit: February 06, 2019, 07:48:17 pm by hotter
Logged
ataradov
Super Contributor
Country:
Re: Same button for two circuits
Reply #1 on:
February 06, 2019, 10:28:13 pm »
That depends on how everything is connected. In general you can't just share the button.
But what you can do practically depends on what the button in the car is doing and what the button in the MP3 player is doing.
Logged
Alex
sokoloff
Super Contributor
Country:
Reply #2 on:
February 06, 2019, 10:43:51 pm »
Hope that the car steering wheel button is putting the data onto a CAN bus, where you can pick it off the bus easily in digital form and do whatever you want with it.
Google your car model/year, aftermarket headunit control, MCP2515, and CAN bus.
Logged
Psi
Super Contributor
Country:
Reply #3 on:
February 06, 2019, 11:14:20 pm »
Some of those steering wheel buttons are just an analog signal with different value resistors put across it depending on the button pressed.
So if you can find the signal you can tap onto it and read the voltage.
Aftermarket car stereos often have a wire to connect to this, then you go into the options and click "learn" so it can learn what voltage means what button.
Logged
MavMitchell
Contributor
Country:
Not my real name
Reply #4 on:
February 07, 2019, 12:06:17 am »
As Psi indicated, the buttons will just be different value resistors connected to ground.
You would have to switch the wire from its original location to your circuit when you want to use then switch it back for its original purpose, otherwise the original functions would occur.
You might be able to find a function like a long push or something that has no effect on the original that you could detect then electronically disconnect the original for a period while you control your player.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
