I have a stm32 board, using a HC49 crystal for HSE. I want to confirm the drive level does not exceed the crystal manufacturer's power limit (0.5mW).
Following the approach in 4.4.2, p13.
http://www.emcu.it/DOC-Digitale-Generale/AN2867%20Oscillator%20design%20guide%20for%20ST%20microcontrollers%20rev5.2.pdfWith,
F=8MHz xtal datasheet.
ESR=60ohm xtal datasheet.
CL1=CL2=15pF
Cs=8.5pF (implied from CL1=CL2=15pF)
Cprobe=9.5pF "A typical 10Mohm probe is 9.5 pF"
Vpp=0.8V measured with scope at drive pin of crystal.
I calculate,
> var square = x => x * x;
> 60 * square(3.14 * (8*1e+6) * ((15 + (8.5 / 2) + 9.5)* 1e-12)) * square(0.8 ) / 2
0.000010014198528
== 10uW.
The crystal is rated at 0.5mW, which is a big margin (50x). As long as I haven't made any mistakes with formula, values or units.
My gut says this detailed calculation is overcomplicated and unnecessary, and if common parts are used, and it starts oscillating then it's probably good enough.
On the other-hand most schematics show an optional current-limit resistor to reduce power.
Does 10uW sound reasonable for a mcu crystal drive-level with typical ESR and cap and Vpp values?
Is there a better (simpler) approach?- other than taking measurements with a current-probe which I don't have.
