Hi there,
I'm currently working on a project with a microcontroller @3.3V powered from a buck converter (MCP16301) like that:
DC Jack --[18 V]--> (Buck) --[3.3 V]--> (MCU)
Next thing to do is place an ISP header for programming. However, most programmers supply 5V and I'd like to avoid any damage in that case.
So I guess I need a VReg (LDO) for 5V->3.3V conversion (and a logic level converter, but that I manage), right?
DC Jack --[18 V]--> (Buck) --[3.3 V]--> (MCU) <--[3.3 V]-- (LDO) <--[5V]-- ISP
So I'd end up having both regulator outputs in parallel powering VCC, which is a bad idea
(FET reverse body diode would conduct through the inductor, LDO could also go up in smoke, ...)
To resolve this situation, my first thought was to use two diodes as a "wired-OR".
However introducing a Vf drop after regulation is nonsense.
https://www.maximintegrated.com/en/app-notes/index.mvp/id/636 explains how to make use of a FET for reverse polarity protection. Using the circuit from fig 5 after each of the regulators, however, I end up having both FET's gates and sources in parallel, making them both conduct at the very same time => short circuit between both regulator outputs, again (Screenshot 1).
I came up with a solution after all (Screen 2). But it seems overcomplicated, doesn't it?
What do you guys think? Is there an easier way out?
Being a newbie, I'm grateful for ANY feedback. Thanks!
Cheers,
Felix
