Author Topic: Scattering Parameters of a connector  (Read 509 times)
Offline RFbeginnerTopic starter
« on: July 15, 2019, 06:31:30 am »
hello everyone,
I'm trying to deembed some filters on transmission lines and in order to do so i need to figure out the S-Parameters of the connector,
i found out the Phases easily, i produced 2 Transmission Lines that are lossless and adjusted to 50Ohm, one of Length L and the other one of Length 2L and used matlab to find out the phases and it works perfectly while comparing the measured and simulated results of my Hybrid  but now i'm kinda stuck to exttract the amplitude, does anyone have an idea how i can find that using the two transmission lines that i already have :) thanks a lot
Offline Nitrousoxide
Re: Scattering Parameters of a connector
« Reply #1 on: July 16, 2019, 04:33:07 pm »
Call me naive but couldn't you just perform a Short Open Load Through calibration on the VNA that you used to measure the filter? It will push the reference planes (ideally) to the ends of the connectors so you won't have to worry about de-embedding (unless you're in a situation where you cant re-measure the filter).  It's a different story if you're using a test fixture where you can't eliminate it.
When you say "phases", do you mean the phase propagation constant? or the total phase change for the length of coax that you're using? That would be the electrical length if its the latter.
Either way, you'd need to find both terms of the complex propagation constant, both alpha and beta. Alpha is measured in nepers per meter or about 8.7dB per meter. You can then find alpha, and you already know beta.
Am I understanding this correctly? I'm a bit confused by the wording: Are you trying to shift the reference planes to the end of coax connectors, or do you have a filter that you want to remove too?
