As I stated above, I ran the 2 tests on the new diode. The results are as follows:
The new diode tests as no component / bad using the Peak tester. The new diode tests bad using the Fluke on
diode test setting. Both results are the same as with the old diode. I did get a reading of ~ 230 Meg Ohms using the
Fluke's resistance setting in one direction and OL [infinite] in the other.
I then tried testing both diodes using a 9 Volt battery in series with each diode using the Fluke's 40 Volt DC setting, first in forward bias, then reversing the leads to reverse bias the diodes.
Forward biasing showed 4 VDC, reverse biasing showed 0 VDC.
I think
bdunham7 explained the mystery: the standard DMM diode test function is designed to test diodes with an ~ .6 V forward voltage drop, whereas this diode has a specified maximum forward voltage drop of 10 Volts [see attachment].
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiFguLu7eyDAxWlOkQIHW6xCZ0QFnoECBMQAQ&url=https%3A%2%2Fsupcache.miancp.com%2Fdata%2Fwww.hvgtsemi.com%2Fupfile%2Fpdf%2F2018050711530586978.pdf&usg=AOvVaw34Rod-SvIiqyMZwuBg51WX&opi=89978449This explains why inserting a 9V battery in series with the diode and making a DC Voltage measurement accurately tested this diode. Lesson learned.
Now, the question becomes: other than HV diodes such as found in this case, what other types do we need to be aware of that will require the insertion of a voltage source - or other alternative procedure - to check accurately?
