I'm beginning my journey down the road to repairing a Dell E2210 LCD monitor. The screen is very dim but otherwise works.
After searching for bad capacitors and failing i'm now taking the advice from this forum to explore replacing a possibly bad CCFL backlight tube. I opened up the backpanel (LG
LM220WE1-TLP4) and located the 2 very small backlights -- one running horizontally along the top and another along the bottom. The entire backlight (from white end cap to end cap) measures about 490mm length (not sure the actual CCFL tube size since it enters the endcap) and 2.45mm diameter.
Inspecting the tubes, one tube has a serious burnt stain at the endcap. When i plug the light in it does not turn on. For the other tube with no visible signs of problems, it turns on but only half of it lights up.
Is there a way to open the endcaps to replace just he CCFL bulb or must i find a replacement backlight assembly complete with endcap and wiring? I assume the electrical requirement for a similar sized tube would all be the same as long as the wiring connector is similar.
