Author Topic: Schmitttrigger doesnt work  (Read 1060 times)
Offline JuculianDTopic starter
« on: October 15, 2018, 03:21:32 pm »
Hello!
I am not very experienced in the use of schmitt triggers (experience=0) and designed a circuit.
For my application, I need 3 channels but I don't want to have an inverted signal.
I have used a 74HC14D (NXP) which has 6 channels.
To not have an inverted signal, I have connected the output to the input of an other channel of the chip. Therefore, in my theory, the signal should be inverted again.
It is not a nice solution, I know, but I thought, I could just use those 3 spare channels because I don't need them anyway and save using an inverting circuit.
BUT!
It doesn't work.
I have made some PCBs and tried it out, but no matter which input signal I put in, the output is high all the time.
Can somebody help?
Is my circuit not possible, or ist the error somewhere else?
(I am using it in my 3D Printer, maybe I am reading it out wrong. I will make some measurements now.)
Thankyou very much!
Julian.
Offline retrolefty
Re: Schmitttrigger doesnt work
« Reply #1 on: October 15, 2018, 03:31:24 pm »
Wiring diagram appears correct. Nothing special about schmitt trigger so better check your testing procedure or test equipment usage.
Good luck  :-+
« Reply #2 on: October 15, 2018, 03:38:59 pm »
Thank you very much.
You are making me couragous, because I was quite sure that my circuit is crap  :-DD.
I will test it now and give feedback soon.
« Reply #3 on: October 15, 2018, 04:00:39 pm »
You are right!
It works as it should :).
There is something wrong with my chinese crappy board, it is too bad engineered to compare 0,00V to 5,1V  :-DD.
Thanks for all the help,
the thread can be closed.
Online MarkF
« Reply #4 on: October 15, 2018, 04:06:54 pm »
Glad you have it working.
You might consider a cleaner trace routing:
« Reply #5 on: October 15, 2018, 04:31:38 pm »
Oh, yeah.
I dont care about the schematics, but the PCB looks odd.
I must admit, I was just using the autrouter...
Thank you for your help,
this forum and Dave's videos are helping me a lot  :clap:
