Author Topic: Schottdy diode or rectifier for reverse protection?  (Read 4244 times)
Offline level6Topic starter
« on: January 31, 2020, 09:56:37 pm »
I need to add reverse current protection to my project and plan to add Schottky diodes/rectifier parts to do this.
Is there any difference between a Schottky diode and rectifier? I'm reading that rectifiers are for converting AC to DC and diodes for blocking reverse voltage, yet most of the examples I have found for reverse protection use Schottky rectifiers, not specifically diodes.
Some products are described as Schottky diodes and some as Schottky rectifiers. Is there really a difference?
« Last Edit: January 31, 2020, 10:54:56 pm by level6 »
Offline Wimberleytech
Re: Schottdy diode or rectifier for reverse protection?
« Reply #1 on: January 31, 2020, 10:18:20 pm »
OK, the IEEE dictionary sez!
Rectifier circuit element: A circuit element bounded by two circuit terminals that has the characteristic of conducting current substantially in one direction only.  Note: The rectifier circuit element may consist of more than one semiconductor rectifier cell, rectifier diode, or rectifier stack connected in series or parallel or both, to operate as a unit.
So, rectifiers consist of one or more diodes.  The diodes can be semiconductor junction diodes or Schottky barrier diodes.  Sometimes a product advertised as a Schottky rectifier contains two Schottky diodes and three terminals.
EEs are not known for consistency and precise language.
« Last Edit: January 31, 2020, 10:21:21 pm by Wimberleytech »
Offline Vovk_Z
  • Country: ua
« Reply #2 on: January 31, 2020, 10:18:52 pm »
Diodes are used to rectifire, so TS question has no sence.
Offline WattsThat
« Reply #3 on: January 31, 2020, 10:42:22 pm »
Schottky diodes are sometimes used in the application instead of standard silicon rectifiers due to their lower forward voltage drop, 0.2-0.3 volts for Schottky verses 0.7 for standard 1N400x rectifiers.
Offline GerryR
« Reply #4 on: January 31, 2020, 11:57:48 pm »
I believe the Schottky "rectifier" would be used in a higher current application versus the Schottky diode which would be used in a signal diode application.  The rectifier version would have a slightly higher forward voltage drop, due to physical construction, but not significantly higher, and still lower than conventional silicon diodes and rectifiers.  Both are much faster in switching applications than the standard diodes, both in the forward and reverse directions.  JM $.02
Still learning; good judgment comes from experience, which comes from bad judgment!!
Offline gbaddeley
« Reply #5 on: February 01, 2020, 12:44:29 am »
Rectifiers are actually diodes, but with ratings and packaging (multiple diodes) that make them suitable for rectifying applications.
For reverse voltage protection on output of a power supply, schottky are good because they conduct at a much lower voltage than silicon, so are more likely to protect the rest of the circuit. However, the max required current limit needs to be considered, so the diode won’t blow. What external device could be connected in reverse, and how much current could it source? 1A 10A 100A?
Glenn
« Reply #6 on: February 01, 2020, 01:10:06 am »
I plan to use the Schottky to protect a device from having it's power supply plugged in reverse. It's for input protection. The rectifier I'm looking at, STPS1L60, has a forward current of 1A and the device draws at max about 28ma.
Offline mariush
« Reply #7 on: February 01, 2020, 01:30:01 am »
You should look into a p channel mosfet to do reverse voltage protection
if you're only dealing with low voltages the zener diode could be missing, i think. and with such low currents cheap tiny mosfets would be doable.
See also appnote showing 3 reverse voltage protection circuits and explaining them: https://www.infineon.com/dgdl/Reverse-Batery-Protection-Rev2.pdf
This is also informative: https://www.maximintegrated.com/en/design/technical-documents/app-notes/6/636.html
Offline Vovk_Z
  • Country: ua
« Reply #8 on: February 01, 2020, 09:10:45 am »
If every mV drop matters then yes. But he say 28 mA load current so simple 1A rated Shottky diode will have 0.2..0.3 V voltage drop.
« Reply #9 on: February 01, 2020, 04:51:29 pm »
Yeah, adding a MOSFET would be a bit overkill. I've tested my circuit with a Schottky in the SOT-123 package and it's working fine, plenty of voltage left over to run the circuit.
