Thanks for the tip with the current, that solved it: The current vs voltage drop graphs on the datasheet goes down to 0.1A, so i just assumed that the reading on my multimeter should be at roughly the same voltage. I just tested them with 2A, they behave completely normal at that current (10A are specified in the datasheet, but i see no point in going that high if the Vf is within the specified range at 2A).
