Hey guys,
I would like to develop a source meter for photo voltaic application(+2V to -2V).Can any one suggest me a source circuit for my experiment.
To answer your topic: Sense lines for voltage feedback. Pretty much all SMUs have them, as do many of the better power supplies.
Are you looking for a circuit for an entire source meter or just what is required to add remove sense to a regulator? The later is pretty easily done in a few different ways as shown below.
If you want a +/-2 volt range, then you need something more like a class-B or class-AB output stage with remote sense.
Note that with remote sense, you can place a current meter in series with the output and not affect the voltage at the remote sense point.
Hi David ,
Thank you very much for the reply.
Can I use this remote sensing circuit for measuring current measurement (10uA to 1A) with series resistors 10K, 100R and 1R operated by relays?
Sure that will work. The sense resistors could even be switched by power MOSFETs. The remote sense will remove the voltage drop from the sense resistors and any switch.
But like I said, if you want an output which can go both positive and negative, a different output stage will be required than a simple voltage regulator. It will resemble an audio power amplifier output stage.
If you want to measure currents that low, then some attention will need to be paid to make the remote sense circuit not draw too much current itself but that is not difficult. Remove sense bias currents from nanoamps to picoamps are easily feasible using operational amplifiers as buffers.
Hi david ,
Could you please tell me about this Rp resistor . Is it a series resistor to measure the current .Could you send me a circuit with MOSFET s to work in both positive and negative(+2V to -2V and -1.5A to 1.5A) .it will be a great help for me .I worked with MOSFET IRF9540 and IRLZ24 in the attached circuit .
This is essentially the same configuration as a MOSFET AC solid state relay but you are probably directly driving the MOSFETs without a photo-voltaic source.
Hi David
I connected the Photo voltaic cell as in the below circuit .
