I have a small portable outdoor camera. It is powered by 8 x AA batteries.
I would like to detect when the device is recording. It does not record all the time but only when something is near or when there is noise.
Using a multimeter, I found out that the device use approximately 200mA when it's recording (with a peak of 1-2A at start). Then (once recording session is done) it fall back to 0.00A (the best I could measure with the multimeter). It's probably below 1mA.
I have been thinking into using a current sense module like the ones based on
MAX471 or
ACS 712 to measure current and trigger something.
Is there a better or simpler way ? (eg : measuring voltage in a resistor using an opamp)
My ultimate goal is to output a +5V or +3V signal when device is recording.
The problem of the modules above is they produce a voltage which is a function of the current (eg : 100mv/A)
