Author Topic: Searching For Brightest RGB LED  (Read 2278 times)
Offline symbianasTopic starter
  • Country: lt
« on: February 20, 2023, 07:46:36 pm »
Hi, I want to focus light to acrylic fiber optic cable and want brightest RGB LED.
I have one like this 5050 SMD WS2812 LED Chip:
Aliexpress link
Do you think this is RGBW would be brighter?
Any other similar variants? (~5mm size)
Offline JustMeHere
Re: Searching For Brightest RGB LED
« Reply #1 on: February 20, 2023, 07:54:55 pm »
Go search digikey.com
Offline themadhippy
« Reply #2 on: February 20, 2023, 08:06:16 pm »
depending on use,you might be surprised how little light is needed to be seen at the end of a fibre cable.A few  years ago i used a small single led torch to light a large star cloth
Offline james_s
« Reply #3 on: February 20, 2023, 08:07:36 pm »
You can get RGB LEDs rated for many watts, the higher power ones will require an external driver IC though.
  • Country: lt
« Reply #4 on: February 20, 2023, 08:25:53 pm »
I have went through it and for me "luminosity" values in documentation seems to be "random", not sure if I can trust them, some LEDs look the same but "mcd" values are 2x higher. Not sure If I want to test them...
The problem is that I want to light entire acrylic fiber cable.
I want something without external driver if possible.
  • Country: lt
« Reply #5 on: February 21, 2023, 05:07:16 am »
Would this be what I am looking for?
https://www.digikey.lt/en/products/detail/adafruit-industries-llc/2741/5804104
Although I don't see any specs for luminosity and how to drive it. Only that it uses PIC driver?
Also I found this 5050 150MA RGB LED:
https://www.digikey.com/en/products/detail/solidlite/HL5050A-3C-150MA/13251237
How could I drive this? Does driver board for it exists?
Offline Psi
« Reply #6 on: February 21, 2023, 06:28:58 am »
Brightest will be something like a 100W COB RGB LED.
but you'd need a focusing lens setup to get it small enough to feed down a fiber.
And it has no driver built in.
https://www.aliexpress.com/item/1005004713012104.html
« Last Edit: February 21, 2023, 06:30:55 am by Psi »
Offline svetlov
  • Country: ru
« Reply #7 on: February 21, 2023, 08:38:00 am »
  Dear Symbi! For your application you need to pay attention to single laser LEDs with mono -color - blue - green - red - they work well in light guides - but losses can be up to 50 percent - a converging lens can be used for color mixing - for this purpose you can try to use the input lens from the microscope - use it the other way around - as shown by the arrows on the photo - input of 3 lasers of three colors to the wide end - output of a light guide glass tube to the narrow end - although this idea with additional modifications can be turned into a patent - but in the new future everything will belong to everyone - and no one can fit anything for himself - everyone will unite and create for the common good
« Last Edit: February 21, 2023, 02:41:53 pm by svetlov »
Offline svetlov
  • Country: ru
Online Zero999
  • 0999
« Reply #9 on: February 21, 2023, 08:42:46 am »
Not enough information has been provided by the original poster to answer the question.
Does the LED have to have a built-in driver?
What's the cross-sectional area of the optical fibre?
How important is colour mixing?
What are the power supply requirements?
Dimensions?
Cooling?
Offline svetlov
  • Country: ru
« Reply #10 on: February 21, 2023, 09:17:03 am »
 or it is possible to use three or four separate lines without an input converging lens - and mixing should be done at the output of the light guide tubes - ideas can be viewed
« Last Edit: February 21, 2023, 09:43:17 am by svetlov »
  • Country: lt
Re: Searching For Brightest RGB LED 3-10mm
« Reply #11 on: February 21, 2023, 09:33:03 am »
Would be great, but would be ok to have separate driver board also. Would be great if controllable with MCU.
Optical fiber diameter 3mm. I can use lenses up to 10mm.
Must be at least RGB.
20mah-1A, would be great if controllable with MCU.
Dimensions?
LED diameter from-to 3-10mm.
Cooling?
Better solution without cooling.
Offline svetlov
  • Country: ru
« Reply #12 on: February 21, 2023, 09:38:00 am »
 symbianas- for what purpose do you need this system - for us your plan is blurry - so the answers are blurry
Online wraper
  • Country: lv
« Reply #13 on: February 21, 2023, 09:39:53 am »
LOL, but you trust random ones without any specs from Aliexpress. Luminocity spec is not random, it can be orders of magnitude different at the same current depending on technology and binning. Similar package means nothing. One manufacturer can make similarly looking LEDs in the same package that have 100 times different brightness.
« Last Edit: February 21, 2023, 09:48:50 am by wraper »
