As Dave has said he got a good deal on the shelving as it was a range being discontinued. In any case this style is quite common, being generically known as wall band, and with various systems being available. Otherwise you are able to make it yourself using simple sheet plywood as a base, with it being cut to length and as wide as the equipment you are using.
There has been some discussion on this recently, search a little and you will find it.
