Finally, I got the HD107 strip and a bunch of 24v to 5v buck converters. Got some ESP32 too for use with WLED.
But, there is a problem.
I bought a 24V power supply from Amazon to test everything. While there is a power LED on the device illuminating when turning it on, after connecting the 24 to 5v buck converter, there is a strange buzzing sound. It's really loud! Also, the power LED blinks like I guess 50hz (the mains supply frequency).
Then I connected the LED strip to the power supply and there should be a test LED program which should run but while it runs (very slowly), the whole strip blinks at the same 50hz ish frequency.
I'm guessing the power supply is faulty?
What do you guys think?
