Indeed, free refills sound awesome, if you do a lot of prototyping. Maybe I was wrong, however 120 Euros for a single 100mm x 100mm PCB is just too expensive for me.
Some news about the quality of my PCBs manufactured by Iteadstudio (or their contractors):
One of my coworkers bought a cheap USB-Microscope for use in our office (Electronic Design Department), which arrived here today. Of course I used it on one of the PCBs manufactured by Itead which I happend to have around.
Maybe you remember from one of my earlier posts in this thread that I talked about (supposed) stopmask-errors on some of the boards.
Bad:
Good:
Well if you take a look at the pictures you can clearly see that they have some sort of issue with their electroplating process (0.5mm THT vias, IIRC). Maybe it's related to their drill process too, as the holes of the defective vias seem to be a lot smaller than the holes of the vias that correctly plated through.
In their defense I got to say, that the PCB I have inspected with the microscope is one of the PCBs that wasn't electrically tested. I guess paying the extra 10$ for a 100% e-test might be well worth it.
I got to check the board that I actually soldered my components to. I am not sure if I used one of the e-tested (markered) board.
Over all I am still pretty happy with the price / quality ratio. It's just something I think you should know and look out for when you're dealing with them.
Cheers,
Florian
