Author Topic: Segmented LCD Driver HT1622/HT1621  (Read 2937 times)
Offline Sultanpepper123Topic starter
  • Country: eg
« on: October 08, 2019, 08:19:27 pm »
I've been leaning working on using and interfacing a microcontroller with an HT1622 + a custom segmented LCD. IMO the datasheet of the IC is very small and left me confused ; is the interface SPI ? UART ? GPIO and PWM (manually) ? . I've searched alot and found several tutorials and github libraries and they seem to not use the SPI feature.
So far (DATA) is MOSI  , CS is "CS" , WR is SCLK and RD is MISO ?  :-\
 Any helpful advice/thoughts would make a world of difference. Thanks in advance.
Note : I've included some of my findings, hopefully someone might add in the missing pieces.
 1. Datasheet http://file.yizimg.com/332467/2009070510405297.pdf
 2. Arduino Uno example code https://github.com/kuwatay/Arduino/blob/master/Segment_LCD_HT1621/Segment_LCD_HT1621.ino
 3. Arduino tutorial for a chinese HT1621+LCD module http://arduinolearning.com/code/ht1621-6-digit-7-segment-display-example.php
 4. Another Tutorial on module https://www.instructables.com/id/How-to-Wire-the-6-Digit-7-Segment-24-Inch-Ht1621-L/
Offline ebclr
Re: Segmented LCD Driver HT1622/HT1621
« Reply #1 on: October 08, 2019, 08:30:42 pm »
It's a kind of synchronous serial but rely on RD and WR signals, also you need to handle when is data and when is comand,
This data sheet is very clear
https://www.holtek.com/documents/10179/116711/HT1622v270.pdf
The following users thanked this post: Sultanpepper123
  • Country: eg
« Reply #2 on: October 09, 2019, 06:13:59 am »
So its not SPI ? bitbanged IO implementation ?
Offline mikerj
« Reply #3 on: October 09, 2019, 11:18:11 am »
Looks like you'll have to bit bang it.  It's somewhat SPI-like but has separate clocks for reading and writing with a common data line.  Pretty stinky tbh.
