Author Topic: Analog panel meter fix?  (Read 3128 times)
Offline ikrelTopic starter
« on: October 31, 2012, 11:15:47 pm »
I just got a panel meter in a grab bag  ;D, however i can't adjust the meter to zero. Does anyone know how i might be able to fix it?
Offline Psi
Re: Analog panel meter fix?
« Reply #1 on: November 01, 2012, 12:12:47 am »
So the zero-adjust screw does nothing?
or it adjust the needle but cant get back to zero?
If you take the case off you might be able to fix it, depending on what the problem is.
« Reply #2 on: November 01, 2012, 12:14:10 am »
It will adjust but not go to zero. in the pic it's as close as it will get.
Offline pickle9000
« Reply #3 on: November 01, 2012, 01:19:21 am »
By chance can you adjust the needle to be dead center? If so it may have the wrong faceplate on it.
...mike
« Reply #4 on: November 01, 2012, 01:26:46 am »
I can center but it's at the extreme end of the adjustment
Offline Psi
« Reply #5 on: November 01, 2012, 01:42:17 am »
I'd take the top off and have a look at the center adjustment.
The spring may have slipped a few turns (hard to fix) or it may have a plastic stop for the adjustment screw which you can easy bypass.
Offline vk6zgo
« Reply #6 on: November 01, 2012, 01:44:10 am »
That's why it was in the "grab bag".
If you take the face off,you may find that the extension on the bottom of the coil which is meant to fit over the adjustment pin,is bent,so lacks adjustment.
You may be able to straighten it,or just set the zero & put the face back on.
