In detail, this is a difficult question.
If you want to make sure to select the appropriate part, you would have to look it up in the service manual.
The suppliers have different series specific for ESR, lifetime, temperature rating, size, mounting options and more.
Polymer caps have an excellent ESR, but suffer from leakage current, so ideal for power supply filtering but inappropriate for signal path or timing applications.
